Hi @DL7BJ, @MZwa, @sven-e and @swinguk,
I want to prepaire for the v0.4 release which include CBUS/VLCB support, are there any must have regarding CBUS/VLCB that are missing?
I have to admit that I haven’t explored all features in Traintastic to answer that. I have only used Traintastic as a control panel for setting turnouts and viewing sensor statuses. This works fine.
I have not tried to use a throttle to run a train with CBUS/VLCB yet.
Thanks @sven-e, good to hear it works fine as a control panel, that is also a use case I’d like to support ![]()
Similar to Sven I’ve concentrated on layout control, where I’ve had no issues. I’m using turnouts with feedback, sensors, and also to display the status of a couple of signals, and have no current issues / feeling anything is missing.
Kinda excited to see Cbus appear!
I haven’t seen things that I would consider blockers..
Things I would love to collab on to debug further? Yes
Things on wishlist? Sure
( think reporting/ overviews / rfid via Cbus? Sure nice to have or wishlist)
Unfortunately my layout is still offline
New Cbus command station to order soon because I blew mine
Not directly related to the CBUS support itself, but viewing the latest Development User Manual, there’s no obvious mention of CBUS/VLCB in the Advanced topics / Interface Configuration section of the manual, unlike most of the other supported interfaces.
That one is missing indeed, I’ll add it and post a link here for review, so you guys can give some feedback. (I’m not an CBUS/VLCB expert.
@MZwa You can post them here as bullet points: Summary of feature requests for CBUS/VLCB , for those you want to describe in more detail or discuss, please create a separate topic and link to it.
I’ve added a CBUS interface page, same style as the others: CBUS/VLCB - Traintastic manual
I believe the essential functions are in place. I can toggle I/O, including servos, monitor the position of turnouts, and run trains. There is nothing standing in the way of a 0.4 version!
But, it doesn’t mean going to rest on laurels now, even if things have been a bit quieter on my end over the last few weeks
On my todo list are signals and Railcom with CBUS/VLCB. I think, signals are not a problem, because the servo controlling is good.
Good to hear!
Signals indeed should just work with CBUS/VLCB, there is currently no feedback for signals however, if there is a need for that I can add it.
There is RailCom support for a few other protocols, so most plumbing is there, once you have some hardware I’ll add it ![]()
This makes me wonder, are the currently any known CBUS/VLCB modules that utilize ASON1, ASOF1, ASON2, ASOF2 etc. messages, the short/long events with additional 1, 2 or 3 data bytes?
There’s a couple of really minor updates I’d recommend to the page:
Thanks, Stephen
Thanks @swinguk, I’ve processed the feedback ![]()
Do you happen to know (or can lookup in the MERG wiki) what the default port number is for the CANether? Is it 5500 as used by JMRI for the CBUS Hub?
Regards,
Yes, a quick check of the manual shows 5550 as the default port to use.
Thanks Stephen, then I’ll set that as default ![]()
Hi All,
I’ve created a CBUS/VLCB group, as experiment. I’d hope that will help future users more easily to find others that use CBUS/VLCB too. I’ve added you all without asking
but you can leave it as you like ![]()
Would be nice to see more CBUS/VLCB Traintastic users ![]()
